- Thread Starter
- #21
The rad is absolutely needed. Without it cpu temps will start to rise dramatically after 10 minutes. My thinking with submerging the rad is that it would force the rad to work more efficiently as both a heatsink and heat exchanger. Also I'm using straight water; you could probably drink the stuff- is that bad?
The serious limitations I have found with this rad is its high fin density. While this may seem counter intuitive especially as traditional wisdom hold that more surface area=better performance the fin density of this rad is such that low pressure case fans cannot push air through the fin. Ideally i would have a high powered and high pressure fan to use with this rad but the noise produced would be deathning in such a set up.
I threw about 5 trays of ice cubes into the drawer of water and my temps dropped to load at 28c.But they melted in like 5 minutes so it was a short lived foray into extreme cooling lol. isn't it impossible for water to freeze simply by throwing in ice cubes into(Not that i presume to be well acquainted with the laws of physics but i did see a episode of magic school bus that implied the above fact)
I see a lot of possibility for this setup if i was to do it well. I'm going to replace the rad and somehow upgrading the drawer. Integrate an aquarium into the loop and show off the setup or hide everything.
