Hey all. I finally got my Mushkin pc3000 from newegg.
I installed it, and unlocked my CPU.
it ran fine at 7x166 but i bumped the multi to 9 and i never
got a post, or a boot, just a black screen.
i whiped off the conductive grease and cleaned my XP
off real good. works fine, but only on normal bios settings.
i tried to run it at what my crucial was at. cas 2, and 2-2-5-2-1
@ 155fsb. no go. it would boot the first time, but once i got
out of the bios i got this BSOD error message.
PAGE_FAULT_IN_NONPAGED_AREA
so i reboot like it says and it also says change hardware blah blah
the usual BSOD.
it hangs up on where it would check my drives and all and
where it would say "DEL to enter BIOS and F1 to continue"
it says "F1 to continue and DEL to skip memor"
it hangs up there and i can't press DEL or F1, totally frozen.
so i reset CMOS and all is well at stock everything.
i also have a new 430W antec true power PSU if that makes
any difference which seems to be doing fine. my CPU temps are
fine at 34-39.
Running on Windows XP home edition
ANY help at all would be greatly appreciated as i really wanted
to push this mushkin. just ask if you need more info, THANKS!
the usual BSOD.
fine at 34-39.
