- Jul 16, 2010
Hi All,
I am new here so am hoping not to commit forum suicide. I have spent about 4 hours reading and searching on here to make sure that I don't post on something that already has a current thread. I couldn't find anything but please feel free to point me to a thread that is already discussing my particular issue if there is one.
Right to the nitty gritty. Basically the situation I am in now is my own fault. I have upgraded my rig looking for better FPS and performance by throwing hardware at the problem. After reading some posts on various forums I thought that I would try overclocking as an alternative and possibly a pointer to a solution.
I am a gamer. There is only 1 game I play. World of Warcraft. So besides email, browsing and updating my monthly budget in excel, World of Warcraft is what I use my machine for.
I recently had the misfortune of been the victem of a lightning strike to my telephone cable. This as basically fried some components which were then to be replaced by insurance. I decided that it was time to upgrade and went ahead and got a GTX260 to replace my GTX8800, a newer mother board that can run DDR2-800 ram. These upgrades unfortunately didn't help as I cn set my graphics settings at ULTRA or at the lowest and still get 18 FPS in raids.
So then I started reading, as I should have done in the first place and one of the things that I read was that WoW is a CPU limited game meaning that the faster your CPU the better the game runs. I have to admit thinking back at this point, that WoW did run better on my P4 3ghz with a MX440 card, compared to now. So....whats better than a Core2DUO? Well a Core2QUAD ofcourse. So I ordered myself one. Once again I should have read before shelling out the bucks.
Right so now you know what has led me to where I am now. So while waiting for the C2Q I ordered, I looked into overclocking to see if having a faster CPU would really make the difference cos quite frankly going from an 8800GTX to a GTX260 and not seeing an improvement was bringing me close to tears.
My first overclock was attempted on the following rig:
E6600 C2D 2.4ghz
KingMAX DDR2-800 2gb x 2
ECS G31T-M7 mobo....(OMG I know its crap.....now)
Geforce GTX260
Gigabyte G-Power cooler
Thermaltale X-Series case with several fans
This was a very short foray into overclocking cos that board does nothing. So while waiting for the C2Q to arrive, I bought a new motherboard and replaced the ECS with an ASUS P5Q SE2 Turbo. The reason I bought this board is because it looked to me, the nooob overclocker, like a board I could use to overclock various chips and ram and not break the bank. I think at this point I should mention that I live in South Africa. We are usually 3 - 5 years behind the rest of the world. An exaggeration I know but you get my drift, so I have to make do with what I can afford.
Right so I popped in the mother board and started reading on overclocking here. The only thing I did was change the Ai Tuner to manual and then upped the FSB to 333 (leaving everything else on auto) which for the E6600 at x9 was slightly over 3ghz. I tried going to 3.15ghz (according to another post I found) but got an error in Prime95 on one of the cores so backed it down to 333 again. Fortunately or unfortunately for me, this did make a marked improvement in WoW for me. In high density areas with medium settings I am now getting 50FPS upwards which is a 100% improvement. In raids I am seeing maybe a 50% improvement, however we have crap internet in SA so I can't be sure.
Ok so questions part 1:
1) Could I have overclocked the E6600 past 3.15ghz if I had played with the vcore, NB and DRAM voltages and timings? (At this point I had not gone into this site indepth)
So now enter the C2Q Q8300 2.5ghz. Popped this in and booted WoW and unfortunately really couldn't see an improvement. Also I reran some SuperPI tests and found that the Q8300 was performing on par with the overclocked E6600, meaning I was getting very similar execution times back.
This is when I started to really get into this website and the forums and read up....which in hind sight is what I should have done right in the beginning. So now I have manually tweaked my ram timings to 5-5-5-18 (which is stock for them I believe), PCIE = 100mhz, NB strap = 333mhz, DRAM Freq. = 667 and I left all the voltages on auto as I am not clued up as what to do their. I upped the Q8300 FSB to 374, which is 2.8ghz (7.5x) and it was running stable with prime95 and none of the cores going over 47 degrees Celsius.
Questions part 2:
1) What is a stable speed that I should aim for on the Q8300 in my particular scenario?
2) How would I go about getting to it? I think this would need a better explanation of how to determine the best voltage to use. I did go through the C2D/C2Q overclockers guide on this site but it is from 2007. Is it still valid?
3) Did I just waste my money by buying a C2Q to try and get a performance improvement in WoW when I should have infact bought a C2D 3ghz and overclocked it?
I do realize that some of this post of mine is jumbled and maybe not strictly in the correct place so I do apologise for that. Any advice or suggestions would be highly appreciated.
Many Thanx
Draco
E6600 C2D 2.4ghz
Geforce GTX260
Questions part 2:
Many Thanx
Draco
