- Dec 13, 2003
- Saint Louis, MO USA
While I was shopping around for coolants and such today at Western Auto, I was stopped in my tracks by an incredible sight. They were really great looking radiators manufactured by Hayden Automotive and are intended to keep transmission fluid cooled.
I jotted down some info:
"Imperial Automotive Products by Hayden Automotive"
"Econokool" is the economy model, although for a computer it would be fantastic. It is all aluminum and shiny. I found the fins to be extremely fragile however. If you find one on a retail shelf, be sure to open it up and check it. I managed to straighten out a few fins just to see if I could correct the cosmetic inperfections. No problem with that at all!
1. Model 242009, 5" X 12-3/4" X 3/4" $29.74
2. Model 242010, 5" X 15-1/2" X 3/4" $????? not on the shelf
3. Model 242016, 7-1/2" X 15-1/2" X 3/4" $38.74
4. Model 242018, 10" X 15-1/2" X 3/4" $48.74
Pros:
Nice looking, and slim.
Shiny Aluminum construction. Even the welds look great.
Cons:
The connection inlet/outlet is snaked down to to fit inside a 3/8" tube, and for most of us, 1/2" ID is a must. However, I believe that you could use a copper pipe tubing cutter (cheap from Home Depot) and cut the pipe off just before it snakes down to the smaller diameter. I didn't have the tools to measure that diameter though. It looked to be very close to 1/2" to me! In addition, I don't think that using hose clamps to secure tubing to this thing would be a problem considering that the kit comes with them anyway!
"MaxiKool XL" is the upgraded line. It has stronger fins, has a better flow design and is painted black with an excellent finish:
1. Model 243007, 7-1/2" X 11" X 3/4" $???? not on the shelf
2. Model 243012, 11-3/8" X 11" X 3/4" $57.74
Pros:
Superior design for the radiator itself. Should be fantastic for heat exchange.
Super looking black, shiny finish. Not a bald spot to be found!
Cons:
Again, 3/8" fittings, and for this one I don't think it could be used with 1/2" tubings because it doesn't snake down like the enonomy line does.
Here's a link to their website:
Ultra-Cool and Rapid-Cool Transmission Cooling
The economy line is pictured in the top half of the web page and the Maxikool is along the bottom. Curiously, the web site refers to them as "Ultra-Cool" and "Rapid Cool" respectively. They look to be identical to what I saw in the store. I pulled them all out of their boxes! If you look closely you can see where the Economy/Ultra-cool product's inlets snake down to the 3/8" diameter. Not so, however, with the Maxikool/Rapid cool product.
If you browse on the site further, you'll come across an engine oil cooler. I don't understand by looking at the picture how the flow works. Perhaps someone has an idea:
Heavy Duty Oil Cooler
I hope you guys find this useful for future WC system considerations. At lease we know this another source of heat exchangers to play with!
MoreGooder
Pros:
Cons:
Pros:
Cons:
MoreGooder
