Hi all, looking for suggestions on a new WiFi router when I move. Off the top of my head, here's what will be on the wifi:
4 cell phones
2 iPads
3(?) PCs
Up to 5 consoles (3 PS3s maybe not all of them on, PS4, Wii U)
Whatever guests bring over
Also, as a geek I need the following features
802.11ac (probably standard feature for why I buy, but better to be sure)
5 ghz (again, just ticking all the boxes)
Static IP assignment (I have two servers)
Gigabit LAN ports (again for the servers, maybe for the unmanaged gig switch to get my PCs and PS3 a wired connection)
If the stock router firmware is pretty solid with lots of options/tweaks, I won't care about flashing DDWRT/Tomato.
We game online, so making sure the signal and processing power is up to snuff is pretty important.
Some quick research suggest the Netgear AC1900 and the higher end Asuses are good choice, but more info is always a good thing.
My budget is fairly flexible, I'd rather get something fairly expensive and solid than waste time with a cheaper option that may cause headaches.
4 cell phones
2 iPads
3(?) PCs
