- May 24, 2001
Im pretty new to this, but Ive been reading alot of posts the past couple of days. Here's my problem: I've got a Athlon 1.2Ghz TypeC CPU and an MSI MS6380 mobo. The CPU came with a Volcano III. According to PCAlert (came with the mobo) Im getting CPU temps as high as 63C. This is with the machine at an idle. At first this really shocked me. Im not overclocking..but then I realize its about 85F in the rooom. I turned the computer off, removed the case cover and waited till the next day. The room temp was about 25C when I turned the computer on and immediately went into the bios to check the temps. The BIOS reported the CPU temp as 35C and chassis temp as 33C. How the !@#? can the chassis temp be 33C when the room temp is 25C, 10 seconds after I turn the machine on?? So I let it boot Win98SE and sit for awhile. I come back and the cpu temp is 53C, chassis temp 49C and room temp is 27C. I can touch the heat sink and hold my finger there without burning. I have NO idea where the temps are being taken from but Im beginning to get suspisious about the accuracy. I would like to get a MC-462A and start overclocking but I dont dare until I know I can get good temp reads..HELP!
My system:
Athlon 1.2Ghz @ 1200Mhz
K7T266 MS-6380 (w/RAID)
256MB Micron DDR
ATI RADEON 64DDR
Deskstar 75Gig ATA100 HDD
Maxtor 30Gig ATA66 HDD
HP9710 CDRW
SBLive! Platinum
3 case Fans (two in back blowing out, 1 in front pulling in)
Toshiba DVD
My system:
256MB Micron DDR
ATI RADEON 64DDR
HP9710 CDRW
SBLive! Platinum
Toshiba DVD
