- Oct 12, 2001
- Los Angeles
- Thread Starter
- #41
Meanwell finally suggested this one: http://www.meanwellusa.com/cat_pdfs/c_usp-225.pdf 9.4A and not too big.
I guess around here, you'd have to ask Cathar... I would think Cathar had #1 or perhaps Thorilan?secretweapon said:Nice! Is that G5 #1 for production?
nikhsub1 said:I guess around here, you'd have to ask Cathar... I would think Cathar had #1 or perhaps Thorilan?
Well sort of... if the pump dumps too much heat, it could be a step backwards yeah. Cathar has estimated that this pump should push about 9lpm through the block with a 120.2, 2m tubing and the G5. I have the 120.3 which should be about the same. The other nice thing about this pump (and the PSU I have) is that I can vary the voltage from 15v to 26v (max of the pump). I am estimating the RD-30 dumps approx 45w of heat into the loop at 24v, same as my 3 D4's but the RD-30 has more pressure than the 3 D4's and will require a lot less tubing and bends with the one pump. We shall see how it goes.pwnt by pat said:Wasn't it once mentioned that having too powerful of a pump on Cathars new blocks would actually have a decrease in performance because of the resistance of the block is so high: it would force the pump to work harder, raising the temperature of the water higher than it would be with a weaker pump?
