- Jan 31, 2008
Hey all,
After recently building a Q6600 system that OC'ed to 3.2ghz stable, I decided to try the X2 AMD path. I recently purchased an AMD Athlon 5000+ X2 Black Edition. Stock clock rating is 2.6ghz and the chip comes with an unlocked multiplier. The current motherboard I'm using is an Abit AN52, and the memory is Patriot Viper Extreme DDR2800.
Here's my experience so far using a Zalman 9500s cooler and stock thermal paste:
Out of the box I was able to quickly change the multiplier from 13x to 15x, resulting in a clock speed of 3.0ghz. This was done on stock voltage.
Core temps are inaccurate so I had to go by Hmonitor readings for the actual CPU. Here are the resulting temps:
Idle: 35c
Load: 55c
This setup was 2-Thread Prime95 stable.
I wanted to try and get clock speeds a little higher, so I tried flipping the multiplier to 15.5 while keeping the FSB at 200. This resulted in a clock speed of 3.11ghz and was also 2-Thread Prime95 stable. V-core was increased a tad to 1.375. Temps are:
Idle: 37c
Load: 58c
This is as high as I was able to get my processor to go by increasing just the multiplier/fsb/v-core.
Here were my failed attempts (that all resulted in stable Windows boot-up's but failed Prime95).
Mhz-----Multi----FSB-----Vcore----------------------Prime95
3080-----14-----220-----1.40 / 1.425 / 1.45-----Instantly failed both threads.
3195-----15-----213-----1.40 / 1.425 / 1.45-----Failed thread 2, 4min in.
3210-----15-----214-----1.40 / 1.425 / 1.45-----Failed thread 2, 3min in.
3200-----16-----200-----1.40 / 1.425 / 1.45-----Failed thread 2, 3min in.
My ram is definitely a decent O/C'er, so the results that failed when increasing the FSB must mean my mobo (which isn't the best) can't cut it.
Any insight on what to try/change would be great.
Thanks for looking
Idle: 35c
Load: 55c
Idle: 37c
Load: 58c
Thanks for looking
