- Jan 12, 2001
- Kansas, USA
Got my new system togather last night (see green rig in signature). Here are my first impressions.
1) CPU looks cool with no pins. After hearing about how fragile the LGA775 socket was, I was being very careful about installing the CPU. There are a couple of tiny notches that you line up so the CPU will only go in one way. When I tried closing the hold-down cover, it didn't seem to go all the way down. I took it all back out and looked at it again. Seemed ok. I tried again. Same deal. I pushed the lever down with a little more force. There was a audible snap when it locked into place. That scared me, but apparently it was supposed to do that.
2) The CPU cooler mounting holes on i915/i925 mobos are completely different than the socket 478 mobos. Meaning you need a heatsink designed for the LGA775 socket. The Thermaltake Jungle heatsink I bought is of a similar design to the Intel retail heatsink. Basically it mounts onto the mobo the same way. There are 4 legs with a type of push pin clip. I found out the hard way that you push the pin down until it clicks and then you turn the head of the pin clockwise to lock it into place. Apparently I didn't lock two of the pins and accidently tested out the thermal throttling of the CPU and high temp shutdown feature of the mobo. After I reseated the heatsink, all was well.
3) The PCI-E version of the Radeon X800 XT that I have requires a special power connector that apparently no power supply has yet. So, the vid card makers provide an adapter that comes in their retail box with the vid card. Trouble is, I got an OEM vid card to save a few bucks, so the adapter was not supplied. The card gives an error beep and a warning message when you turn on the computer and stops the boot. I found an article and pic over at Driver Heaven that described how to "hot wire" the card. Something else to be aware of if you you build a system with a PCI-E vid card.
4) The i915/i925 mobos recommend using a 24-pin power supply. No problem, I bought an Antec True 550w 24-pin PS. My Abit AG8 mobo will work with a standard 20-pin ATX power supply, you have to follow the instructs on which 4 pins to leave open. The extra power pins provide additional juice to the mobo power circuitry to feed the hungry Prescott. I think there is 24-pin to 20-pin adapters, so I bet there will soon be 20-pin to 24-pin adapters too.
5) CPU info: P-4 Prescott 540 LGA 3.2 with 1M of L2 cache and 800 system bus. S-spec=SL7KL, week 26 of 2004, and made in Malay. Default vcore=1.3625v.
6) Cooling and temps: I have four 80mm case fans: front intake, side cover intake with duct, rear exhaust and top blowhole exhaust. CPU cooler is a TT Jungle installed with AS3. Stock N/B cooler and vid card cooler. Temp at default speed (204 FSB for some reason) is listed below.
Idle temps: CPU=43, Sys=33, PWM1=35, PWM2=36
Load temps: CPU=60, Sys=34, PWM1=43, PWM2=44
7) Overclocking first impressions. So far I'm not a happy camper. I only got 3.4 gig out of it last night before I hit a wall. I must admit I haven't figured out the N/B voltages yet. The BIOS settings are different than what I'm used to, so I'm still learning. The Uguru thing allows overclocking in the Windows environment, so I'm testing that too. I was also using the original 11 BIOS. I just now updated the BIOS to version 15, but haven't tested it yet.
8) I will post more later when I get more time to tweak stuff. Feel free to ask questions or better yet, offer suggestions on how I can get a higher O/C.
