- Thread Starter
- #41
Too cool, at least you know it's not your case cooling. you cant go lower than Ambient on cooling. What is your load temp with your desk fan?
Still around 90 :/
AIO?
What are temps in AIDA64 Stress test?
All In One, any water-cooling that is "plug and play" so to speak, not custom.
Have you re-tested with Aida64 and/or Prime95 26.6 ?
Does your one pump hose feel warm at 90c+, what prime95 version were you getting 90c?Oh boi, checked all the tests, the highest spike was 98C... But it was mostly around 92
Yep, replied to the other guy
**** now prime95 spikes up to 100C!!!!
What in the god damn is this ****
Boi, alot of questions here
Uhm, regarding the paste, it looks more on the pic due to the flash than it really is, comparing it to a YT guide, its just slightly more, it cant possible make those temp differences?
I used to have Pure Rock, before the OC times more or less, its SUCH a hassle to replace the water system with regular again, so I am afraid that will be for now, unless I get unemployed and get alot of spare time
90C seems to be the max when doing Prime 95 26,6 version, the big test (whilst looking in the Realtemp)
Yes one of my hoses from the CPU is feeling slightly warmer than the other
I have ASUS Z170-A (LGA1151)
Host pictures here at the site please. Those will be invalid, and some cant see them anyway.
Are you sure you need that much voltage for 4.5ghz??? We generally say not to go over 1.42V for 24/7 and you are already there. Id try 4.2 and 1.2V and see if that works...
Are yoy adjusting vomtage manually as you should? Auto tends to over volt man!
Passed the ROG RealBench stress test for one hour with these settings:
•47x CPU Multiplier
•1.408V CPU VCORE (Or less)
Test equipment:
•Motherboard: Asus Maximus VIII Hero
•Memory: 8GB 2133MHz 15-15-15-35
•Cooler: Corsair H105 AIO
•Thermal Paste: Arctic MX-4
•Ambient temperature: 22°C
under the limit.. which is all we need to know, lol!Would like to know what sort of temps they hit with that AIO...
What are your settings, a GHz, temperature.
As of 5/3/16, the top 59% of tested 6700Ks were able to hit 4.7GHz or greater.
•47x CPU Multiplier
Test equipment:
Depending upon your setup, frequencies achieved can be ±100MHz.
https://siliconlottery.com/collections/lga-1151/products/6700k47g
Set the memory to 2133, turn off all power saving settings, set the Vcore to 1.33V (make sure its not offset voltage), set the core clock to 4.4GHz with 44 x 100mhz, and set the LCC to the middle setting. try booting it up and see what happens.
