Okay, I ordered one of those squirrel cage fans, a 48V 240cfm Patriot, which I might add is almost silent and the perfect cfm at 12V for a backup unit on my radiator assembly, but my imagination took over my wallet when I bought one of those soda fountain refrigeration units, just to dissect and see what promise it held for extreme cooling. It was chocked full of accessories crucial to its original use and packed with injection molded insulation which took seval hours to chisel off, but underneath was a very nice, compact refrigeration unit.
The assembly with the compressor, cooling radiator and fan is a rectangular shape almost perfect for sitting a tower case upon. Reference the multimeter in the picture for an idea of the size.
Notice the temperature
Coming out of the top is an interesting heat exchanger. It is a flexible/moldable large aluminum sheet with coolant channels molded into it.
The entire aluminum sheet can be wrapped around something
like a large water reservoir or more to my imagination, rolled up into a spiral which you could put a fan on one end of and blown through, the approaches are as limitless as your imagination.
I'm trying to envision putting the heat exchanger inside my case and sealing it up as best as possible, allowing the heat exchanger to cool the entire inside of my PC.
The compressor and fan assembly are amazingly quiet, even with the covers off. I'd say about as loud as my current water cooling setup with 4 case fans. I could quite easily hear my wife and daughter talking upstairs with it on. It doesn't draw a lot of current either.
I may experiment with it or throw it up in the classifieds. I'm pretty complacent with my current water cooling setup, yet it tickles my imagination.
Hoot
