- Sep 5, 2002
- Minneapolis, MN
Man who cares bout that extra 100mghz. It would have been nice to see but you just did what alot of ppl cannot do with their 2.8ghz. chips.
formosian said:As an enthusiastic overclocker, I just want to share my joy and excitement with the fellow overclockers. I believe that nothing beats finding a monstrously overclockable chip for those never satisfied overclockers like I am.
p.s. Pardon my bad English
jdmcnudgent said:if you put the wire on tight, it should stay on when you switch. also, that will see what kind of th7II you have, its running at 158fsb right now. would be nice to see if you could run it at 177 or so, without problems.
Rasputin'sLiver said:
Hi Mica - I'm running 40b for the extra volts. i have the 7e, but what is the defoger mod?
40b is rock solid except for cold boots which is really a minor inconvenience to me since i rarely cold boot this machine... even when i do, i get it running without too much trouble
hmmm. if i wasn't stuck watching the baby, i'd try it right now!
yes, the drcg chips are memory related.micamica1217 said:about the drcg chips....this is only for the memory or somthing???
its OK dude if you cant do 3600. 3500 is just fine, and i mentioned earlier in a post, you prolly have the best chip on the planet.formosian said:Ok guys looks like the party is over.
After about 1 day bruning in, she still refuses to stay stable at 3.6GHz no matter what votages which the max is 1.725V for IT7. At 3.5GHz, you can just throw about anything to her and rock solid.
Regarding the seti bench stuff, I will give it a shot later on when I come back from work. So stay tune.
I really don't care about people who believe this amazing overclock or not. As an enthusiastic overclocker, I just want to share my joy and excitement with the fellow overclockers. I believe that nothing beats finding a monstrously overclockable chip for those never satisfied overclockers like I am.
Anyway IMHO a 3.5GHz air cooling chip is just about the best you can find on this planet at this momnet. I think it will stop my hunger of hunting a good chip for a while.
micamica1217 said:
the defoger mod is were you paint the holes that the cpu pins slide in. instead of wire raping...just paint the holes with rear window defoger repair kit.
mica
jdmcnudgent said:yes, the drcg chips are memory related.
certain chips on the board hold the mem back. people have soddered better chips on in hopes to take their board higher. for more info, check here, these are the search results for drcg chips.micamica1217 said:
but how???
I think you can't go over pc1200 or so speed...am I close or somthing???
and how does it hold it back?
mica
jdmcnudgent said:certain chips on the board hold the mem back. people have soddered better chips on in hopes to take their board higher. for more info, check here, these are the search results for drcg chips.
yes, all of your boards are nice boards, but it is holding up my theory of not being very nice above 165fsb.micamica1217 said:
thanks jd,
but what I'm getting at is some peeps had crappy boards....bad capasiters next to cpu gave undervolting, the drcg's holding back the memory and so on.
yet it seems that ras, azn and I got the good boards...the ones that don't undervolt and have no hold backs from the drcgs and such.
I just could not use kingston 1066....thats not bad.
pc948 speed is very fast.
mica
jdmcnudgent said:yes, all of your boards are nice boards, but it is holding up my theory of not being very nice above 165fsb.
lutjens said:That's one helluva chip....that chip's yields are about the same as what a new 3.06's yields. Intel must have been really hard up for 1.8 CPU's (Dell was probably screaming for more of them) and Intel was forced to speed bin some of the faster chips to satisfy their order.
I doubt they'd do the same for retail channels. They knew what they were doing when they remarked the faster chips as slower ones, but I guess they justified it by knowing that Dell is an OEM builder with no overclocking at all. So by speed binning the chips they wouldn't be losing anything (as they would potentially in the retail market).
you stated that you tested up to 164, get it stable at 170-175, prime stable, seti stable, and then come talk to me, you ARE wett.micamica1217 said:
I still dont understand.....I can do above 165fsb.
mica
I can do it really good and they call me bananna hands.Rasputin'sLiver said:
you're right jd. but remember when you helped me do the wire mod several months ago on my 2.26b? it was such a hassle with my big hands and bad eyes that i've just left it alone in my bd72-raid where it's humming along happily at just under 3ghz. the th7II is the better overclocking option though with rambus and all...
whad you say bananna hands??Big Nuttz said:I can do it really good and they call me bananna hands.
if intel wanted to cruch AMD real fast all they have to do is send out every C1 1.8a like the one here......I know I'll buy two.
