Hi folks,
I've been having some on-going issues with my PC and would really appreciate some advice on where to go next. I've installed RAM, GFX card, sound card myself before but am a noob when it comes to the rest of it - like motherboards! Please read the below and if you can help me with any of the questions at the bottom, i'd be extremely grateful!
Bit of background information:
I've had this PC for 3 years. Last month it stopped working and the screen went all distorted and purple with blotches. Unusable. I assumed it was the GFX card and as I was due an upgrade anyway, ordered a new one. I replaced my 3 year old nVidia 768MB Geforce 8800GTX with a new ATI RAEDON 6850 1GB.
Of course things are never that simple and the problem remained, except now the PC wouldn't even boot up, just made a loud beeping noise. I had 4 1GB sticks of RAM at that time, so by removing/re-seating sticks I used trial and error to narrow the problem down to one of the actual slots that the RAM fits in to. Now I was down to 3 GB RAM, so I ordered some 2GB sticks, bringing me up to 6GB. It could be 8, but as mentioned one of the slots is buggered. I've no idea if that can be fixed!
Another thing is that the sound has never been great and I've always had problems with headsets/mics. Can't have speakers AND headset plugged in at once, have to swap them as needed, plus I haven't been able to get a mic to work in years. Bought a new sound card and 5.1 speaker system a while ago but they are crap too and infact in the last month the sound is worse than ever. I bought two new headsets, one fancy 'fatality' jobby that plugs into the ports on the sound card, which doesn't work. And then a USB one, thinking that would bypass the soundcard - it doesn't work either.
The performance of the PC isn't great at the moment, it grinds a fair bit and struggles on occasion. The Windows 7 test thing you can do under My Computer gives a mark over 7.0 for most things, but 5.8 for disk speed. I'm hoping an overdue re-format will freshen up the speed a bit, but I just want a PC that runs new games with decent FPS and that has working sound and voicecomms.
Moving on, these are my current specs:
Windows 7 64BIT
Intel Core 2 Duo Q6600 QUAD CORE
Processor Speed 10,640 MHz
6GB RAM
ATI RAEDON 6850 1GB
Motherboard Manufacturer: ASUSTeK Computer INC.
Motherboard Model: P5N32-E SLI PLUS
CPU Family: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Model 15, Stepping 11
CPU Speed: 2400 MHz
CPU Manufacturer: GenuineIntel
Available Memory Slots: 1
Total Memory Slots: 4
Dual Channel Support: N.A.
Creative SoundBlaster X-FI Xtreme
Creative Inspire T6100 5.1 Speakers&Sub
The type of RAM I have is
2GB, 240-pin DIMM, DDR2 PC2-6400 memory module
CT25664AA800
* Module Size: 2GB
* Package: 240-pin DIMM
* Feature: DDR2 PC2-6400
* Specs: DDR2 PC2-6400 • CL=6 • Unbuffered • NON-ECC • DDR2-800 • 1.8V • 256Meg x 64 •
Each memory slot can hold DDR2 PC2-6400, DDR2 PC2-8500, DDR2 PC2-5300 with a maximum of 2GB per slot.
Questions:
1. Is there a way to fix the broken RAM slot? Or will I need a new motherboard?
2. Is my current motherboard good enough for modern day gaming? I mean, is it good enough to handle my new gfx card, as I haven't been that impressed so far.
3. I'm thinking my solution to the never ending sound problems is to buy a good sound card, but I'm worried it wouldn't make a difference. Something seems really screwed up somewhere and I'm wondering if it has something to do with my motherboard, or onboard sound interfering in some way, or something like that? Any ideas?
4. Is my CPU good enough?
5. Would you recommend I abandon this PC, take out the gfx card and RAM, buy new components and try and build a PC myself (i'm a noob when it comes to this). Or do you reckon I could upgrade this one easy enough?
Really appreciate any help or advice!
Thanks
Aces
Windows 7 64BIT
6GB RAM
ATI RAEDON 6850 1GB
CPU Speed: 2400 MHz
CT25664AA800
* Module Size: 2GB
Questions:
Thanks
Aces
