- Aug 13, 2009
- Thread Starter
- #21
Gonchi,
There are always risks for over clocking but mild and conservative overclocking leaves very little risk to your components. Overclocking should be done conservatively if you are new at it and in graduated steps with the tests above at every overclock increase. Generally if your overclock is bad, it will fail Memtest86 without entering your operating system so you reboot and make your corrections. Most good boards won't let you boot into a dangerous area, it will just stop.
For instance, my overclock in my signature is very mild compared to the experts here. I am on stock cooling and voltage and that's enough for me.
As an added precaution, get Core Temp and run it minimized with the temps showing in your task bar and monitor it closely. I try to avoid temps running Orthos that go over 70C. That's my self-imposed conservative limit for my E8500 chip.
I am not familiar with your motherboard so you may want to ask redduc for a more conservative beginners overclock to start with and try it.
ok, so the overclock redduc posted is conservative ? what i am most worried about is the 4890 since it is the most expensive part... but the risks are all 4 the cpu and mobo arent they ?
