- Jan 29, 2012
- Detroit, MI
I'm new to overclocking and wanted some OC veterans to take a look at my setup and offer some tips/advice/suggestions/etc. I've spent the past few days reading through threads that are specific to my setup and I've also read through some overclocking guides. I've learned a lot but probably just enough to be dangerous.
I am using IntelBurnTest to stress test and RealTemp to monitor the core temps. I was able to run the stress test for an hour with the setting as shown below but the idle/load temps on the first core were 45C/93C. I've read that the max temp is 100C and most overclockers like to stay below 80C so my temps are a concern to me. I don't have the best cpu cooler; it's a Cooler Master Hyper N520 #RR-920-N520-GP with the fans in a push/pull configuration exhausting out the back. I ordered a Thermalright Venomous-X RT and IC Diamond TIM in hopes to bring those temps down.
Advanced Frequency Settings:
CPU Clock Ratio ................................ [21x]
QPI Link Speed ................................. [x36]
Uncore Frequency ............................... [x17]
>>> Standard Clock Control
Base Clock (BCLK) Control ...................... [Enabled]
BCLK Frequency (MHz) ........................... [200]
PCI Express Frequency (MHz) .................... [101]
>>> Advanced Clock Control
CPU Clock Drive ................................ [800mV]
PCI Express Clock Drive ........................ [900mV]
CPU Clock Skew ................................. [0]
IOH Clock Skew ................................. [0]
>>> Advanced CPU Core Features
Intel(R) Turbo Boost Tech ...................... [Disabled]
CPU Cores Enabled .............................. [All]
CPU Multi Threading ............................ [Disabled]
CPU Enhanced Halt (C1E) ........................ [Disabled]
C3/C6/C7 State Support ......................... [Disabled]
CPU Thermal Monitor ............................ [Auto]
CPU EIST Function .............................. [Disabled]
Bi-Directional PROCHOT ......................... [Enabled]
Advanced Memory Settings:
Extreme Memory Profile (X.M.P.) ................ [Disabled]
System Memory Multiplier (SPD) ................. [8.0]
Performance Enhance ............................ [Turbo]
DRAM Timing Selectable (SPD) ................... [Quick]
>>> Channel A/B/C Standard Timing Control
CAS Latency Time ............................... [6]
tRCD ........................................... [8]
tRP ............................................ [6]
tRAS ........................................... [20]
>>> Channel A/B/C Advanced Timing Control
Command Rate (CMD) ............................. [1]
Advanced Voltage Settings:
>>> CPU
Load Line Calibration .......................... [Level 2]
CPU Vcore ...................................... [1.3875v]
QPI/VTT Voltage 1.150v ......................... [1.355v]
CPU PLL 1.800v ................................. [1.8v]
>>> MCH/ICH
PCIE 1.500v .................................... [1.5v]
QPI PLL 1.100v ................................. [1.1v]
IOH Core 1.100v ................................ [1.2v]
ICH I/O 1.500v ................................. [1.5v]
ICH Core 1.1v .................................. [1.1v]
>>> DRAM
DRAM Voltage 1.500v ............................ [1.64v]
DRAM Termination 0.750v......................... [Auto]
Ch-A Data VRef. 0.750v ......................... [Auto]
Ch-B Data VRef. 0.750v ......................... [Auto]
Ch-C Data VRef. 0.750v ......................... [Auto]
Ch-A Address VRef. 0.750v ...................... [Auto]
Miscellaneous Setting:
Isonchronous Support ........................... [Enabled]
Virtualization Technology ...................... [Disabled]
>>> CPU
>>> MCH/ICH
>>> DRAM
