Possibly. The 2700 ram stick itself will be able to handle the highert fsb, but the real question is will the rest of your hardware handle it? the memory may yield a little higher fsb but then you run into probs with your hardware getting screwy. Good luck. also, to check if yoor hardware will cause probs, drop the mult and up the fsb. Your chip may run slower, but this is mainly to see if your other components can handle the fsb.
