- Apr 29, 2002
I'd go ahead and set the voltages the same as the first unless there are cooling issues with the first rig. Then after the OS is installed, set it to 75% of the first rig's OC. Ramp it up after that if all is well.
c627627 said:I got one for you hitech man:
Let's say you buy two identical systems. Same CPU codes, etc...
Your system gradually does such and such overclock stability tested.
What do you do with the second system from the get go, I mean in what increments considering you know what the first one did approximately?
Do you boot at stock at all, or do you jump to what FSB and what voltage since the system is identical to the first one. Let's say it's a PC2100 RAM situation and let's say 1800+ B. Let's say 152 FSB max with 15 multiplier. Vdimm up one notch, 1.8 volts Vcore...
How many reboots in what increments to approach the first system's overclock?
johnoh said:seems like something isn't right between the tt sf2 and the 80mm vantec in that you're getting an extra 11C of cooling for only 9cfm difference.
Is ambient the same for each? 15C for sys temp is damn cold.
johnoh said:So would you say perhaps the sf2 75 cfm is overstated? Seems like the 50% higher fins of the vantec would give it more than an 83cfm vs 75cfm advantage, especially given the rpm difference.
Since87 said:
[Ignore the blue line. I added the blue line to indicate the pressure drop vs flowrate curve for a heatercore in another post.]
johnoh said:That makes sense to me. Especially since the 25mm high sf2 will result in a higher flow resistance since the meat of its fins is about 33% closer to the sink.
But even in open air, I have a hard time believing a 10% cfm difference between a 25mm fan versus a 38mm fan operating at 20% higher rpms.
So aside from your work (nice work here btw) showing that an undervolted tornado may be the best fan for normal use (I couldn't handle the volume of it at 5000+ rpm), I think it shows that tt may be overstating their case.
