- Aug 13, 2001
- Deep Blue Sea (Maryland)
have any of you guys using the tweaked BIOS (1004.013 from x86-secret) but having a lower overclocking core speed???
i'm using 2 stick of 512MB Corsair PC3200LL (low latency) memory. it's rated at 200MHz @ 2-2-2-6-1T. so, memory shouldn't be a problem at all.
however, on my 2.4b, i could "only" get 3.1 with tweak enable. but i could get 3.2GHz if i turn it off (disable virus protect in BIOS)..........
no matter how much core v. i apply, 'cos when enable, up to 1.7v actually voltage, still can't start window @ 3.2GHz (locks up when the screen shows the tweak is enable after detecting the RAID drive), but when i disable it, i could run 3.2GHz at 1.65v actual voltage. memory voltage is set to 2.7v.
have you guys tried to turn it off and see if you can o/c higher??
