- Apr 20, 2001
- Sacramento, CA
My 3.4F arrived from overclockers.co.uk yesterday and so did the 6800 GT PCIe card. This allowed me enough parts to bench build the system to do some testing. I hoooked up my new Swiftech H20-120 to give it a quick test, along with an older Thermaltake TWV480 power supply and the Kingston PC5400 I ordered.
So basically what I have running on my desk is the P5AD2-E, 3.4F, Swiftech H20-120 w/ LGA 775 holddown, 1gb of Kingston PC5400 in Dual Channel and that Thermaltake 480watt power supply.
The chip is a SL7L8 D0 EM64T enabled processor, week 21 of 2004 from China. So far I'm up to 3,870mhz on the default voltage (1.32 under load). Load temps are between 42-44C. I enabled CPU Lock Free and set the FSB to 276, Memory is at DDR737 at 1.9v (don't know if I needed the extra voltage or not).
So far, results are looking good. This power supply along with the Geforce 6800 is my major constraint because I don't yet have the PCIe power connector so the card is running on the borderline power wise. After a while I lose display but the system is still running. I'm sure the power cable will solve that problem. But so far it's Dual Prime95 stable for over 12 hours since I can RDP into the system and check stuff out.
My 12v rail is approaching the 11.5x range, so there really isn't much left with this current bench PSU. Once I drop this board and chip into my case on Thursday and make use of the PC Power and Cooling 510 Deluxe, I won't have to worry about power issues any longer. I think everyone will like my cooling loop and pump placement in the PC-1200b. So far I'm extremely pleased with everything. This board rocks and with the 925XE I no longer have to worry about FSB restrictions until the 325mhz range which I'll never see so it doesn't matter.
