- Jul 14, 2002
Is it normal for the heatsinks of an Antec SmartPower 300W (single fan, variable speed) to run 10-15F hotter than those of other 300W PSUs with a variable speed fan? I thought something was wrong, but a second identical Antec got just as hot.
I ran each PSU for 15 minutes with the cover on (heatsinks ran cooler that way) and measured the heatsinks 30 seconds after turn-off (time needed to remove cover and stick in the probe).
The other PSUs had both larger and smaller heatsinks, and they seemed to run their fans with about the same flow rate (deflected a piece of cardboard hung by 2 threads to the same angle). Some PSUs had lots of holes in their cases, others had almost none. But in every case the Antec ran the hottest.
