- May 30, 2004
going down to ddr2 400 (pc3200) allows prime95 to pass most tests with the vcore at 1.350.
At DDR 1 speeds! O_O Your motherboard may have cheap caps.
sorry meant pc2 3200!
1.95 vDIMM is OK, too bad the other settings aren't available.Hi thanks for the reply, I set all the settings to what you suggested but couldn't lower the vDIMM as the lowest I can go is 1.95v in my bios. I don't have the BE version. The ram timing is default to what you suggested.
Prime95 failed on test2 on both cores with the max temp at 52. I've attached my SPD tab details.
Even though those timings were default you still set them manually when you dropped the RAM to 333 MHz, right?
52 is a little high for stock speeds even with the vCore turned up a little. What heatsink are you using on the CPU and how clean is it?
Still, I'm surprised you got a P95 fail with those settings. Have you tried using OCCT instead? I've got one rig that just won't pass P95 regardless of what I do
I've never said P95 is badly written and in all honesty I don't know why one of my machines has a problem with it. It won't pass a P95 test for an hour, yet it's been churning out verified work units (24/7 number crunching) for over a year-and-a-half. You can say whatever you want about P95 being the end-all of stability testing but I'll see your 24 hour P95 test and raise you about 10,000 verified work units over a period of 20 months. Go ask the other Crunchers and Folders which is the better test - I already know what their answer will be.In my experience, Prime95 failing means you're gonna get crashes if you ignore Prime95.
(facepalms at people accusing Prime95 of being badly written) (It's a bad motherboard, processor or PSU!)
BTW - You can run OCCT as long as you like, just like P95. After fritzing around with P95 for three days I decided to test with OCCT and it went through 19 hours before I switched to Crunching. Until then I was as adamant as you about P95 testing but three wasted days changed my mind.
Good idea. As it is it could be the RAM, board, or CPU - no way to really know, though it is odd that several hours of MemTest86+ doesn't show any errors.A update on this issue, seems like something is wrong hardware wise.
This is testing with OCCT
cpu freq 200mhz 2.6 clock speed
400mhz ddr2, vcore at 1.275 - PASS
[trim]
all the FAILS happen within 3 mins of OCCT running.
It seems like if the ram speed is anything above 440, OCCT will fail. It seems like a memory problem but memest86 passes it but I would want to check by trying other sticks, don't want to buy them tho just incase the sticks are not at fault so need to borrow them from someone..
The more recent versions of OCCT have a LinX option, if that's what you need to sustain your illusions of stability.That's why you should maybe try LinX or IntelBurnTest.
