Hey guys, would like to get some help here . I recently got myself a peltier heat pump and I've gona admit that its my first experience with it. I believe my peltier is rather smaller den the commons ones out there (30mmx30mm). According to my vendor, the peltier uses 12v at 3amp current.
At first, I don't have a 3amp adaptor, so I use my 1amp adaptor and powered it up at 12volts. My adaptor got burned within 20mins and you can smell the terrible burned plastic smell from my adaptor . My peltier however is working properly (hot on one side cold on the other).
Next I got myself a 3amp adaptor with auto thermal power off, which means my adaptor will auto power off when over heated. I powered up the peltier and the auto power off triggers within half an hour. My adaptor is damn hot! The peltier is still working fine.
I even try on batteries and my batteries too, heat up like nobodies bussiness .
So anyone got any idea why its like this? Does it matters if the peltier is a cheap one (Cos I got it at a rather cheap price)? Or is it that iI gotton a spoilt peltier? Thanks in advance .
