JT (Apr 04, 2001 05:20 p.m.):
Is there any program that will shut you computer down if your cpu temperature gets to a certain point? If so were can I get it.
Yes, but the min time to shutdown is 10 seconds...more than enought time for a tbird to fry if something goes wrong...I want it to shutdown immeidatley!!! Reach 60C, click...powerdown....
So, set it to shut down at 55C. That's higher than you should run it anyway. Start the process at 55C and maybe it'll be done by 60C. It's the best I could come up with ;D
Ghettoweasel (Apr 04, 2001 06:44 p.m.):
the same place that you download mbm5.0 from ahs plenty of direct shut down programs that you can download also...there are plenty of links to the site from overclockers.com due to it being another overclockers.com link
