- May 15, 2004
Welcome to my first Water cooling project.
Day 1
Im taking my old case, and hardware in my sig, and building my first WC'ed system. In preperation for Conroe and new hardware later in the year.
CPU: 3.2e DO 478
Ram: OCZ Gold 3700 EL
MB: Abit IC7-G Modded and sinked...
VGA: x850 xt pe
HDD: 160gb sata
PSU: 520w OCZ powerstream
Cooling: Swiftech apex ultra kit ++ a heap of fans
Case: 50$ piece of crap from local pc shop, but it is now not so recognisable as anything but unique.
So in this mod im
A. Spray painting it black (Not the top or side windows)
B. Modding the top perspex to hold the radiator and 3 120mm fans.
C. Cutting out sections of the MB plate to allow for alot of cable hiding behind the MB
D. Making mesh grills to cover most of the fans.
E. Masking the Cd-rom and HDD so you wont really be able to see them.
F. Making mesh grill for 5.25' bays
G. Trying to sleeve each cable that will be visible in case not behind MB plate.
H. Getting my water cooling in and seeing if 4Ghz is possible.
Whati want from this mod, is basically experience, in modding and water cooling. Plus a sweet looking rig.
So today i started and hear are the first images.
My bedroom, or should i say assembly room
My Working area, laundry
Spray painted case outside, not bad for first time with the can
Case
Radiator mounted, with two long screws at the back, and attached to 120mm fan at top, it high detail so you can see what iv done.
Bassicaly, i need extra height to be able to properly mount the radiator on top and make sure the radiator barbs didnt sit inside the case, so between the 120mm fan and rad, are 4 gold MB mounting screws, gives me the perfect height.
So the radiator is supported pretty well by the 120 on the perspex, and the two screws supporting it at the back, take most of the weight.
I have about 15 pics so bare with me as i post em up.
^_^
![beer :beer: :beer:](/forums/oc_images/images/smilies/boozing.gif)
Day 1
CPU: 3.2e DO 478
VGA: x850 xt pe
HDD: 160gb sata
So in this mod im
![DSCF2060.jpg DSCF2060.jpg](https://www.overclockers.com/forums/data/attachments/52/52122-bee4062746f5d183953cd1ffcbc781b6.jpg)
![DSCF2061.jpg DSCF2061.jpg](https://www.overclockers.com/forums/data/attachments/52/52123-0ba1446b612eaa1578af169f6fc286bc.jpg)
![DSCF2063.jpg DSCF2063.jpg](https://www.overclockers.com/forums/data/attachments/52/52124-c7262174a5de1c22f8ad84817607ed3d.jpg)
Case
![DSCF2064.jpg DSCF2064.jpg](https://www.overclockers.com/forums/data/attachments/52/52125-fb620133013c296ce6ceebeab73b5d88.jpg)
![DSCF2073.jpg DSCF2073.jpg](https://www.overclockers.com/forums/data/attachments/52/52126-de135b9772b9a9aa797f5dc73b820209.jpg)
^_^
