- Dec 5, 2004
- Milwaukee, WI
After a somewhat flunked Rev. D1 writeup, a 955XE that mysteriously died on me and a straight out fun build (Rev D1.5), I present you with Revision D2 - with more goods than ever, thanks to a few extra hookups (you know who you all are), plus a pay increase at work .
Planned Specifications
Case/Components:
- Enclosure: Custom Black Wrinkle Powdercoated Mountain Mods U2-UFO w/ Original Top - HAVE
- Processor: Intel Core 2 Extreme X6800 2.93GHz Conroe - NEED
- Motherboard: ATi RD600 Xpress3200 Intel Edition
- or Asus P5WD2-E Premium 975X (Conroe Supporting) - NEED
- Memory: 2GB (2x1GB) G.Skill F2-8000PHU1-1GBHZ DDR2-1000/PC2-8000 (4-4-4-5)
- or 2GB (2x1GB) OCZ Platinum XTC DDR2-1000/PC2-8000 Extreme Edition (4-5-4-15) - NEED
- Graphics: Sapphire ATI Radeon x1900XTX 512MB PCI-Express x16 - HAVE
- Sapphire ATI Radeon x1900 Crossfire Edition 512MB PCI-Express x16 - NEED
- Audio: Creative Sound Blaster Audigy2 ZS 7.1 PCI Sound Card - NEED
- Storage: 2x Western Digital Raptor WD740ADFD 74GB 10,000RPM 16MB Cache SATA (RAID 0) - HAVE 2
- 2x Western Digital Caviar SE16 WD2500KS 250GB 7200RPM 16MB Cache SATA II (Backup Drives) - NEED
- 5.25 Devices: 2x Black Samsung CD-RW/DL DVD burner combo drive - NEED
- Power: PC Power & Cooling Turbo Cool 1KW 1000 Watt Crossfire Edition - NEED
- Display: Dell UltraSharp 2407FPW 24.0-inch Wide Flat Panel LCD - NEED
CPU Water Cooling (1/2" ID Loop):
- CPU Block: Little River Waterblocks Storm G5 - HAVE
- Radiator: Thermochill PA120.3 Radiator - NEED
- Radiator Shrouds: 2x Thermochill PS120.3 Shrouds + neoprene gaskets - HAVE
- Pumps: 2x Laing DDC-2TP Rev. 2 "Plus" w/ Alphacool Acrylic Tops - NEED
- Fillport/Reservoir: Alphacool Cape AGB2 Polished Copper Circular Reservoir - HAVE
- Tubing: 100 feet Masterkleer 1/2" ID, 13/16" OD (5/32" Wall) Tubing - HAVE
- Hose Clamps: 10x 316 Stainless Steel Worm Drive Hose Clamps 9/16" band 1" max. ID - HAVE
GPU Water Cooling (3/8" ID Loop):
- GPU Blocks: 2x Swiftech MCW-60 - NEED
- Radiator: HW Labs Black GT Stealth 240 - NEED
- Pumps: Laing DDC-2TP Rev. 2 "Plus" w/ Alphacool Acrylic Top - NEED
- Fillport/Reservoir: Alphacool Cape AGB2 Polished Copper Circular Reservoir - NEED
- Tubing: 25 feet Masterkleer 3/8" ID, 5/8" OD (1/8" Wall) Tubing - NEED
- Hose Clamps: 10x 316 Stainless Steel Worm Drive Hose Clamps 9/16" band 7/8" max. ID - NEED
Misc. Cooling:
- CPU Radiator Fans: 6x Delta WFB1212ME 120x38mm Fans- HAVE
- GPU Radiator Fans: 2x Delta WFB1212M 120x25mm Fans - HAVE
- Case Fans: 4x Delta WFB1212M 120x25mm Fans - HAVE
- RAM Sinks: 16x OCZ Copper BGA RAM Sinks - NEED
Miscellaneous Parts:
- Matched Black Wrinkle Powdercoated Sunbeam 5.25" 4-Channel Rheobus - HAVE
- Matched Black Wrinkle Powdercoated Aluminum Lian Li 3.5 to 5.25 Bay Converter - HAVE
- Matched Black Wrinkle Powdercoated Aluminum Lian Li Floppy Drive Bezel - HAVE
- 9x Black 120mm Wire Fan Grills - HAVE
- 2x Lian Li V-series Stainless Steel Power Buttons + Blue & Red LEDs - HAVE
- 6x Silver Braided ACryan SATAII 300Mb/s Cables - NEED 4
- 2x Cardkeeper CK03-1225 w/ SLI Slot & Liquid Cooling Support - HAVE
- Cardkeeper CK99-1224 - NEED
- 3x Logisys White 12" Dual CCFL Kits - NEED
I bet you’ve asked yourself one question at this point. “Does this kid ever stop!?”
Well he is for once after this rig is done – I need to save up for a car once I turn 18 in January, and this rig will have to last me a while without being upgrades (not like it needs any!)
Anyways… Welcome to Project Three Mile Island - Revision D2
-Justin
