- Dec 5, 2004
- Milwaukee, WI
- Thread Starter
- #21
flat LL V-series switches replace stock MM switches:
BEFORE:
AFTER:
BEFORE:
AFTER:
The Cape Corp AGB2 reservoir serves for easy filling and ventilating a water cooling system. It can be mounted inside or outside the case and provides a water reservoir, by means of which the pump can absorb absolutely free of bubbles. The water cooling system can be filled after the installation via the filling opening at the upper side (oil-inspection glass cover). Through the 1/4" screw thread it is populated with different other connections and thus it can be variably combined with diverse hose diameters. The AGB3 has a M4-drill, in order to fit the bottom to the case.
Technical data:
Weight: 1250g
Material: copper polished (start-up protection), cover oil-inspection glass
Dimensions (without pump): (LxBxH) 50 x 116 mm
Connections: 2x G1/4"
The reservoir is delivered without connections! Please order your wished connections under Hoses&Connections!
ear muffs? my room usually isn't that cold that I need to keep my ears warm... LOLBWR said:Are you planning to wear ear muffs during PC use?
heh... my wallet hates me too, but I know its going somewhere goodCaptain Slug said:My wallet hates you...
Excellent fan choices btw.
