- Sep 20, 2001
- Bakersfield, CA
Now that I got my 4770K ITX HTPC running nicely, it's kind of serving duty replacing my old 2600K retired 'backup rig' in my Phanteks Pro M case.
With Alder Lake on the horizon, not sure I want to do anything crazy right now, because those will be cool toys to play with this winter. But I have some 115X waterblocks sitting here unused, 3 pumps and 3 radiators (thin 240, thick 240, thin 360) and the itch to build a solid project room build for funsies using cooling hardware I have right now, in a case that would readily take a custom water loop.
I like the ITX option even if it's in an ATX case because it can be swapped to the HTPC when that ages out. Both boards have very similar feature sets overall for my purposes. The Extreme board does have a nice layout though. Haven't settled on a CPU, so I'm throwing the 11600KF on there because it's a good price/perf option.
So, pick a poll option to encourage my insanity, or pop my bubble with reason and logic.
I hope the 115x/20xx blocks can be used on the Alder Lake platform as Intel has been pretty good about compatibility the last decade or so for cooling mounts.
