- Aug 22, 2011
- Kansas City
Hello again all, this is going to be my 2nd WC build, please review my WC components and comment opinions are welcome.
P.S. The mobo block stays, its a personal preference, i want the added bling factor. Same goes for the GPU backplates - last time i used a waterblock on a 6970 w/o the backplate i encountered some serious bending.
Mobo Waterblock:EK-FB ASUS Max4 Extreme
CPU water block: EK-Supreme HF
GPU water blocks: EK-FC6970 Acetyl + EN (Nickel) x3
GPU backplates: EK Radeon HD 6970 V2 VGA Liquid Cooling RAM Backplate x3
Reservoirs: Liquid Fusion V Series Reservoir x 2
Radiators: XSPC RX360 rads x3
Pumps: Swiftech mp655 x2
Pump Top: EK-D5 X-TOP x2
Tubing: Primo Chill PrimoFlex PRO LRT Tubing 1/2"ID 3/4"OD
Misc compression fittings etc.
As you can tell ill be running 2 loops - one for the GPUs and one for the mobo + CPU, 2 rads will be devoted to the GPUs while one on the CPU loop.
