ok, i've been looking into a way to mount a delta hha 60x60x10 on my sk6. i plan on trying this out on my msi k7d master. I know the fan only pushes like 21-22cfm, but I'm curious to see how it will do on a 1600.
not bad.
personally, i don't care about the noise. the delta is nothing compared to this v9. i think the fan on the v9 has a higher whine. going to get either a vantec tornado or the delta to put on top this v9.
um... i think skip delted all the old posts... and my comp has since been formatted... and i can't find my digital camera... but you can very easily fit an 80x25mm fan on that heatsink.
Here is a guide for installing 80mm fans onto the thermalright sk-6. It is located under the Heatsink Reviews and Tips section of Overclockers.com Look for the article dated 4/12/02 named Juan's Sk-6 Mod
