- Nov 21, 2018
So. I picked up a 3900x. Till my x570 board came in I decided to plug it in my Aorus gaming 7. Running the latest bios everything was great on my 2700x. Put the 3900x in and won't detect my sata drives or msata.
Needless to say after seeing this I'll stick with the 2700x. Definitely not a fan of having no data drives and the fact this is my first experience with the cpu it was a very bad one. Just a warning to anyone who is using a sata drive on x470 with Ryzen 9. I don't know if this is just a Mobo CPU combo but just thought I would put it out there.
Fixed.
Basically the windows install would just lock up after the reboot to start setting windows up. NDLS error what is an error from the onboard wifi. Fix is pull it out of disable then reinstall windows and then install it from windows after you get set up. Or taking a current driver put it on a usb drive and then install it from that during the install.
The Sata problem is still going on and i have no idea whats going on it it.
Drive worked fine. With the 3900x bios wont detect it. Put the 2700x in and it worked fine. 3900x back in and nothing. Put it in a usb type c enclosure it would detect it but not boot from it. In windows with the enclosure it works fine. So this is looking like a problem with the Aorus gaming 7/bios or the Ryzen 3900X. Same bios the drive works fine with the 2700x so im looking at the 3900x as the cause.
Fixed.
