- Dec 24, 2000
- Milwaukee, WI
:: Seti Instructions and Files :: New Members Look Here!
Welcome!
For all those interested in Joining our SETI Team what follows are the instructions to set up the Command Line client (The fastest way to run SETI) along with a few monitoring programs too. Thanks go out to Kris (Morpheus) - OC SETI Team Co-Leader for putting this together and thanks to Mictlan for always pointing everyone in the right direction to get started. Be sure to check out our Teams Official Site at http://www.ocsetiteam.com/ for any and all information related to the SETI Project, and welcome in advance to the Best SETI Team to crunch for! Just a teaser shot for you, our current updated Challenge graphs will be shown here as well, to show you exactly what we are shooting for.
Our Current Challenge Graph!
How to set up SETI Command Line
OK... Here is my quick list (with hyperlinks) to making the SETI@home CLC (NOT THE SCREENSAVER), SETI spy & SETI Driver work together... Please note the versions below... the list was written for those versions and may need to be updated when changes occur...
SETI&Home (v3.03 CLC) i386-winnt-cmdline.exe
SETI Spy (v3.20) SETISpy.exe
SETI Driver (v1.6.3.6) SETIDriver.zip
Or just download the all three zipped here (863k) - Updated 09.09.02
Note: the following assumes you have the latest download of SETI@home, SETISpy & SETI Driver ready at hand...
Happy Crunching!!!
Kris
End set up SETI Command Line
Again if you have any questions or need any help in doing the above please do not hesitate to ask and we will do all we can to get you up and running in an Expediate manner. Welcome to the Best SETI Team to crunch for! As always the best for more information is the Website http://www.ocsetiteam.com/ and if that does not help to answer any questions or concerns you may have please feel free to drop a line and ask.
SpeeDj - Last update April 27th 2002, Thanks Sean!
Welcome!
Sincerely, SpeeDj - OC SETI Team Co-Leader
- : If you have previous SETI versions, uninstall ALL SETI programs
- : Create a "SETI" folder
- : In the SETI folder, copy "setiathome-3_03_i386-winnt-cmdline.exe" & "SETI Driver.exe" & "SetiSpy.exe"
- : Click on "SETI Driver.exe"
- : Set "maximum processes" to "1"
- : Set "desired cache size" to "1"
- : Make sure the "hide processing box" is checked (default value).
- : Set "SETI client priority" to "low"
- : "Process monitoring" is at the bottom of the window, make sure the "use SETI Driver" is checked.
- : Click on the "save config" button
- : Click on the "transmit" button (if you get an error window at this point, choose "ignore")
- : A DOS window (the CLC or command line client) will open entitled "SETI 1 - Transmit"
- : In the DOS window, enter "1" or "2" (depending on your status)
* Type 1 to indicate new user.
* You'll be prompted for a valid e-mail address.
* You'll be prompted for a nickname, You can choose anyone of your liking, as SETI users are identified by e-mail not nickname. - : Enter the email address you registered for SETI with (If you are not a new user that is - Otherwise skip to the next step)
- : The CLC will download data, display information on the WU downloaded, then stop when it reaches "beginning analysis"
- : Then CLC should disappear as SETI Driver "hides" the processing
NOTE: You should have a blue radio telescope icon running in the system tray (next to time & volume in the lower right portion of your screen). If this is the case, SETI Driver & the CLC are working together... CONGRATS!!!
- : Right click on the blue radio telescope icon, and select "exit"
- : In your SETI folder, click on "SetiSpy.exe"
- : Select "I agree" (if you do, of course)
- : Click "ignore" (if you get the "error window")
NOTE: You should now be looking at the SETI Spy interface (GUI window). In the white-ish area on the left are what I will call "tabs" (named, "progress," performance," results," etc.). To select a tab, click on it.
- : Select the "client" tab
- : Click on the "configure" button, this will open the "client configuration" window
- : Click on "browse", this will open the "select SETI@home Client" window
- : Click on the "SETI Driver.exe"
- : At the bottom of the window it should read [file name: SETI Driver.exe] [file type: executables]
- : Click on "open"
- : The "select SETI@home Client" will close, and the "Client Configuration" should be displayed
NOTE: Assuming I have set this up on a "C:" drive, using the "SETI" folder name as I mentioned above, the client configuration window will read "C:\SETI\SETI Driver.exe" in the "client path" area.
- : In the "client parameter(s)" area type "-SETISpy" (don't miss the hyphen)
- : Under "client control" at the bottom of the window, check all 4 boxes
- : Click "OK" and you will be back at the SETI Spy GUI
- : Select the "Setup" tab (should default to the "display" button setting, if not select "display")
- : check the 3 left boxes in this order: "minimize to tray," "run in tray," "close to tray"
- : Click on the "client" button
- : Check the "Ignore presence of state file on startup" box
- : In the system tray, right click on the SETI Spy icon (radio telescope with magnifying glass) and select "exit".
NOTE: At this point, there should be no SETI icons in the system tray, or other SETI windows open. If anything is open, close it.
- : Click on "SetiSpy.exe" in the SETI folder, if you get an error message (which you probably will) select "ignore".
- : You should have both the SETISpy AND SETI Driver icons now running in your system tray.
- : Left click on the SETI Driver icon, make sure the "use SETI Spy" box is checked in the "process monitoring" section at the bottom of the window.
- : Click on the "save config" button, then minimize the SETI Driver window.
- : Right Click on the SETI Spy icon in your system tray.
- : Select "exit".
- : Next, click on the "SETI Spy.exe" icon in your SETI folder... No errors? GREAT.... CONGRATULATIONS!!!! You are now configured to run the CLC, Spy & Driver off the SETI Spy icon...
- : To get the full functionality of SetiSpy you must do this workaround, it will enable you to update your user info and give you a direct link to our SETI@home team page.
- : Finally double click the SETI driver icon in your tray, set the desired cache size to 3-5 days worth of work units. If you are not sure how many to set it to set it to 10 and see about how many units you complete in a day and then multiply that by 3 or 5. And also if you have a 24/7 internet connection you can click auto transmit otherwise when you cache gets low you will need to connect to the internet manually and then click the transmit button on SETI driver. You may also wish to connect to one of the teams public queues. Save the configuration and you are now ready to crunch.
Happy Crunching!!!
Kris
