- Dec 4, 2008
![Shrug :shrug: :shrug:](/forums/oc_images/images/smilies/gen068.gif)
The problem is...my benching stations are messy with wires ....and finally came up with a simple set up with a DVD-rom and HDD attached in one piece. Minimal expense required and as neatly as possible.
I was going to attach the PSU behind and beneath the top tier...but...enough drilling and brackets already.
(Just in case the thumbnails do not appear, the inserted image links are still alive...
just click on the X out thumbnail for a direct view.)
If you have a problem seeing the pictures.....there is a slideshow >> http://www.megapix.com/flash.php?flashtype=slideshow&itemid=JRLQLIZ1P << for easier viewing.
Just about to finish
![](http://www.megapix.com/?p=AWCBT3CD.jpg)
Power button...done
![](http://www.megapix.com/?p=7LBEQ78X.jpg)
DVD-Writer....can be slided out....to accommodates a discrete GPU
![](http://www.megapix.com/?p=DA1Y4GD3.jpg)
DVD-Writer's bracket
![](http://www.megapix.com/?p=X441VFJV.jpg)
Bottom's view
![](http://www.megapix.com/?p=EZ22VDPU.jpg)
Up and running...top view
![](http://www.megapix.com/?p=GCLWVOG9.jpg)
Side view. There's enough room to insert a screwdriver's tip down to clear CMOS as needed.
![](http://www.megapix.com/?p=86IE4GC3.jpg)
Up close
![](http://www.megapix.com/?p=XTYL6VDH.jpg)
Overall view
![](http://www.megapix.com/?p=W0EKS7ML.jpg)
DONE
![](http://www.megapix.com/?p=LGJB7CH4.jpg)
UPDATED with another PSU mounted in the rear and out of the way.
![](http://www.megapix.com/?p=YDK1VIMS.jpg)
![](http://www.megapix.com/?p=NOXOU8CN.jpg)
![](http://www.megapix.com/?p=SQMWM9F2.jpg)
