Well, pretty much as the topic says. I'm trying to figure out if there is a 8x AGP equipped motherboard for my retro build. I'm thinking Gainward Golden Sample 7800GS+ 512MB or XFX 7950 550M 512MB, both being way overkill for the Celeron 1300 that i got to put in as the over all engine of the bus...
Minimum 3 RAM slots, if possible more, and even better if it can actually use my 512MB RAM, since that leaves me with 1GB RAM, which i would like... A lot.
If there simply isn't anything to fulfill such "needs" i'll simply stick to the 4x AGP motherboard i got. (GA-60XT) But i'm not entirely sure the 7-series GFX are safe to put in a "universal" AGP slot (No keying) so in that case i might downgrade to the Radeon 9500Pro...
Anyway, just wanted to pick your brains, and see if i could get any wiser. I just might end up saving the 7800/7950 cards for the future, if i cant find a way to move forward on this.
Thank you for your time.
B!
B!
