- Oct 29, 2005
- Oregon
I have an Asrock FM2A88X-ITX+ mobo. Everything is brand new except for my data satas. I used atuning to update the mobo. Everything went well until I updated the bios last. It automatically rebooted as it did for all the other updates (audio, .net4.5, vga). At the last boot after atuning updated bios, I booted into the bios (maybe I shouldn't have?) wherein it then did the actual bios update. I can boot into bios fine, change settings, check for updates (there are none), but now when it starts to load windows it immediately gives me the bluescreen of death. Bios uefi defaults, nor using a previous OS image helps at all. My only options are to reinstall and see if that works, or give to someone who CAN fix it. Asrock does have a tech support page in bios too. I may give that a whirl and see if I even get a response.
Does anybody here have a clue what the problem could be? I should have left the bios alone but having done several other bios updates on other boards, not uefi ones, with no problems, I never imagined I'd get a bluescreen.
Thank you for any help or replies.
