Hi i'm new to these forums, but since everyone is soo interested in these JIUHB DLT3C's I have some info to share, I work at a local computer shop, my boss is pretty cool cause I get to test pretty much any hardware I want. Anyways, here are 8 cpu's I have tested, have a look.
Prime tested under windows xp sp1 with ACPI.
Apic, firewire, sata, com1/2/printer disabled.
Motherboard: Abit NF7-S Rev 1.2 (killed 2 already, SAVE AND EXIT MY A**!)
Ram Used: 512 Infineon DDR-333 2.6 volts @ Ram Timings 6-2-2-2.
FSB: 166FSB 5/5 (all tests were at this)
CPU: Many 1700's
Vcore: Ranged (1.5 to 1.9)
Vagp: Default
Chipset: Default (1.6)
PowerSupply: Enermax 460W (33 Amps on +12 Volt). +12volt fluctuated between 11.92- 12.6 volts. +5V never moved @ 5.06. One thing to note is, with my first two rev 1.2 nf7 the voltages were quite a bit higher but they died![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Video: Geforce MX (just for testing)
Bios used is 015, tried 16 and killed 2 boards with bios 16 (not from the flash, but the SAVE and EXiT screen), so I decided not to flash to 16 this time for testing.
All CPU's Were tested with a Vantec Aeroflow and the paste that the fan comes with.
(great heatsink/fan for the price)
First cpu:
AXDA1700DLT3C 9392267-27-1028
JIUHB0310-W-PMW @@1999 AMD
2.166 ghz @ 1.5 volts
2.25ghz @ 1.575 volts
2.5ghz @ 1.825 volts. max temp 55 cel
Posted 2.6ghz with 1.825 volts but did not want to test at this speed with this cooler.
Second cpu:
AxDA1700DLT3C 9392267-27-0025
JIUHB0310-W-MPW @@1999
2080mhz @ 1.5 volts
2166mhz @ 1.6 volts
2500mhz @ 1.825 volts max temp 58.50
posted 2.68ghz with 1.825 but failed to load windows.
Third CPU:
AXDA1700DLT3C 9392967-26-0323
JIUHB 0310-X-PMW @@1999
2000mhz @ 1.5 volts
2338mhz @ 1.775 volts (max temp 52 celc)
Did not test betweem 2333-2500
2500mhz @ not stable up to 1.93 volts
This cpu is kind of a dog as far as the DLT3C's go, starting to see a pattern with the alphabet XPMW, too eary to tell but so far the WPMW seem better/ more consistant.
(any voltage past 1.85 volts these DLT3C's wont boot properly)
Fourth CPU:
AXDA1700DLT3C 930367-25-1151
2000mhz @ 1.4 volts
2171mhz @ 1.5 volts
2250mhz @ 1.575 volts
2338mhz @ 1.625 volts
2408mhz @ 1.70 volts (sweet spot) - 52 cel
Takes a dump after this....
2500mhz @ 1.825 volts - 62 celcius
Fifth CPU:
AXDA1700DLT3C 9392267-27-0029
JIUHB0310-W-PMW @1999AMD
2000mhz @ 1.38 (set to 1.375 in bios)
2166mhz @ 1.5V
2500mhz @ 1.825V (passes 6 hours of prime but not stable)
Sixth CPU:
AXDA1700DLT3C 9392267-27-0743
JIUHB 0310-W-PMW @@1999amd
2500MHZ @ 1.80 voltage (1.76-1.795 actual)
Totally stable, best cpu so far, and runs cooler, at 52.5 celcius...
Only testing max speeds from here on out, getting tired of regular tests, seems these chips do not benefit much from "burn in" like the DUT3C cpu's..
Seventh CPU: AXDA1700DLT3C 9392267-27-1029
JIUHB0301-W-PMW
2338mhz @ 1.62
2500mhz @ 1.80 voltage (1.76-1.79) not stable
2500mhz @ 1.825voltage (1.81-1.82) not stable.. gave up on this one.
Eighth CPU: AXDA1700DLT3C 9392267-27-0625
JIUHB0310WPMW @@1999AMD
2250mhz @ 1.625 volts
2500mhz @ 1.825 (unstable)
K I give up, too tired to keep testing, when we get a new batch of cpu's in at work next week, i'll try to test them as well.
The only conclusion I can make from my limited testing are a few assumptions. Most of the info I heard regarding these cpu's were incorrect like the color of the core, to the "lower the number on the string of digits ""939226727-(0743)" the better. I think this is incorrect. I belive it's just luck of the draw that will yield a cpu that does 2500mhz on air with acceptable voltages and decent temps. After testing numerous cpu's i'm glad I found a cpu that does well, 1.78 volts 2500mhz stable is good enough for me. I hope some of this info helped.
CPU: Many 1700's
Vagp: Default
First cpu:
Second cpu:
2080mhz @ 1.5 volts
2166mhz @ 1.6 volts
Third CPU:
2000mhz @ 1.5 volts
Fourth CPU:
2000mhz @ 1.4 volts
2171mhz @ 1.5 volts
Fifth CPU:
2166mhz @ 1.5V
Sixth CPU:
JIUHB0301-W-PMW
2338mhz @ 1.62
