- Apr 12, 2002
Here is my waterblock Idea.
It it just the center part of the block it will be milled out of a 2x3 peice of copper.
I am planning to build it with my drill press. the bigger holes are going to be drilled with a 1/2" bit and the smaller holes in the middle 1/4"or maybe a 3/8" bit. The reason I decided to make the holes in the center smaller is because the thermal conductivity of copper is 4.01W/cmK compared to water at .6W/cmK so I wanted for the water to contact the copper the most possible (I may be wrong I looked this up on google while writing this). just wanted to know what you guys think.
PS What pressure is supposed to be exerted onto the die of the chip. Have heard from 20lbs to 100lbs.
