- Aug 26, 2003
- Maryland, USA
squasher said:yeah i could use so more tools, but ill collect more and more over my life time (i hope!)
that pneumatic tool looks like a beast, do you have a big air machine (not sure what they are really called)
i think im gonna try the tin snips technique and grind it smooth with my dremel
oh and Susquehannock those are some really nice cuts!
ThanX for the compliments squasher. Tools are like experience. You get more
with age ... usually.
threeme2189 said:what exactly did you make those big holes for?
The biggest one is to cool the back of the CPU socket with an 80mm side panel fan.
The two smaller ones are for routing wires etc.
mtb856 said:looks like he used pneumatic snips or a sheetmetal cutting tool...... they cut through that metal like butter
Nope. Like V!5!0Nz said, I used cut off (grinding) wheels for the straight cuts. Then used the carbide
rotary file in the die grinder for the curves. And the two hand files and
a piece of 220 grit sandpaper for final deburring. Now the edges are safe for a baby's hands.
That rotary file is awesome with some real power behind it. Like carving soft butter.
High volume is what one needs to look for when supplying heavy duty
pneumatic tools, not high pressure.
Most of those cheaper Husky and Craftsman "oil free" compressors are not so
called "tool grade". In other words, you work from the increased pressure
inside the tank. Once that's depleated the output volume drops
significantly while the compressor builds pressure in the tank again.
The heavy duty Cummins compressor in my shop is made to supply
high flow tools with the compressor motor running instead of relying on
high pressure built within the tank for short bursts.
...... i. e. = 18 cfm @ 40 psi, vs. 4.5cfm @ 40 psi
As you can see, the 20gal unit is a little top heavy from the big pump & motor on top.
Most times you have to buy a 50 gal+ sized compressor to get a big pump
& motor like that.
Always a good idea to go with good name brand industrial tools.
