Dividers are locked on this board. It even says it in the bios. Big fat Locked.
My gigabyte canterwood has 2.0 and 2.5 dividers. I can run my FSB at 160 and my memory at DDR 400 or 200MHZ easily.
I went into the advanced options and the RAM is at 2,2,2,7 when set to auto.
I toke the auto off and set the RAM to manual and put it at 2,2,2,6 to start and it seems okay. Then it flashed to boot screen in the middle of BlackHawk down.
So, Its stable at 2,2,2,7 with those settings.
I wanted to see how I could get 2,2,2,5 though as this is what my memory chips are tested at. So, I drop the DDR400 and put it at 160FSB and 2.0 divider. It comes out at 320DDR.
Was able to boot at 2,2,2,5 at this speed, but it also flashed to the boot screen in a game.
So in conclusion,
I think my processor is maxing at 3.2 and needs more voltage. I had it at stock voltages the whole time. I am pretty sure the memory is okay, as I can get it running at 200MHZ in Dual channel if I relax the timings alittle.
I might just drop down to 3.1 so I can maintain stability at 2,2,2,5 and still keep my CPU at stock voltage.
I would get this board LAST. As it has no CSA support.
you know if the NEO2 canterwood has divisors?
This gigabyte canerwood has dividers and TONS of manual options. It is a VERY good overclocker so far.
The ONLY problem I am having so far is the nice Easytuner 4 software is not working with the new chipset. I emailed gigabyte to inquire on it already.
Another perk to this board. The cost is down to 155 now.
