- Apr 13, 2012
- South East Ohio
I'm beginning my OC on my new FX-6300 on a Gigabyte GA-990FXA-UD3 R5 Rev. 1.0. I first watched the voltages to see what core voltage corresponded with what CPU speed. I noticed that the vcore was 1.368v at 3817.5 Mhz and was 1.425v at 4118.9 Mhz. I am now at 3817.5 Mhz with a vcore of 1.368 set manually. One thing I found out about this board is the vcore setting is not added to the base vcore. It is actually the number you set in the vcore value. Some have stated that it's added to the vcore on some other Gigabyte boards but not this one. I have LLC set to auto. I haven't ran prime95 yet but will shorty. I have core performance boost disabled, cpu unlock enabled, cool and quiet disabled, C1E suuport and SVM disabled, CPU core control automatic, Core C6 state and SVM disabled and HPC enabled. Is there anything I missed that I should enable or disable? Any suggestions on what I should do\set in the BIOS?
I let you guys know more how it goes.
Thanks
Thanks
