- Jun 15, 2011
Hi!
I just wanted to share my first HTPC build with you. Up until now I have streamed my movies from a QNAP NAS to a WDTV Live with custom firmware. This has worked ok, I guess, but I wanted something more flexible. The WDTV also has some problems with mkv headers and on some files also a weird audio/video sync issue.
My specific needs would be to stream 24p .mkv-files, and simultaneously run the Spotify client in the background. Spotify will transmit the audio to an Apple airport extreme connected to my stereo at a different floor of the house (PulseAudio for Linux, Airfoil if I go for Windows), and I should be able to control Spotfiy through my Android phone.
Build consists of these parts:
Case: Streacom FC8 Evo Black
Motherboard: Intel DH77DF m-ITX
PSU: Streacom Nano 150W
RAM: 4GB of the cheapest Crucial RAM
CPU/GPU: Intel i3 3225 / HD4000 (TDP 55W)
SSD: OCZ Agility 4, 128GB
Remote: Inteset CIR receiver + remote
Thermal paste: Arctic Silver Alumina
Extra cables: Internal PSU extension (Important!!)
Parts bought, but not used:
Streacom USB 3.0 cable (not compatible with the mobo/case combination)
Build parts (Not too good a camera, sorry for the out of focus):
Now, the cooling solution on this case makes it a bit fiddly to build. This build is completely fanless, and the heat from the CPU is transferred through 4 copper rods to the aluminum chassis. These rods may interfer with several connectors on the motherboard. So if anyone thinks of a similar setup, look at the motherboard layout and think carefully about anything that the rods may interfer with! Also, take care with the Nano PSU. I've read several reports of people breaking it, when handling it too roughly. Also, On my motherboard, the PSU socket sits directly underneath the rods. The PSU is quite high, so without the low-profile extension cord, I would never have gotten it to fit.
Intel DH77DF motherboard:
Inteset CIR receiver and Remote:
Nano PSU 150W:
A good tip would be to connect any cables on the motherboard prior to installing the cooling rods. After assembly, there is not much space left.
Motherboard, CPU, Ram and cables installed:
Now, the heatsink and rods where a little messy. You have to apply thermal paste to several surfaces simultaneously, and this can be messy if you don't take your time. I used a lot of time dry-fitting everything before applying the paste. I also had to bend the rods to get a good fit. Test and adjust, test and adjust. I would also reccomend a non-conductive paste, the risk of accidentaly touching a vital component is present if you're not careful.
What I did was to loosely connect the rods to the CPU heatsink, but I didn't tighten the screws completely. This way, I was able to pull and push to adjust the length of the rods prior to fixating. Take your time here, getting a good fit should also mean better heat conduction.
Assembled heatsink and rods:
You should also dryfit and check that the rods connect well to the chassis. After thermal paste is applied, further adjustment will be messy.
Heatsink and rods installed:
I was going to connect the two front USB-ports to the USB 3.0 internal connector on the motherboard, but that didn't work out. The USB cable does not fit underneath the heat rods at all, even when I bent it to the max. I had to revert to the USB 2.0 cables. Not a big deal for me, but for anyone who needs the front ports to be 3.0, this motherboard/case combo is not for you.
I've read a lot of bad things about Streacoms own remote (buttons not working, not really RC6 compatible etc.), so I wanted to try the a different setup. I was also worried that the motherboard I originally had in mind (ASUS P8H77-I) would have problem waking the machine from S5 state through the remote. The Intel CIR connection should be a safe option, that's why I switched to the Intel motherboard.
The only problem of going down that path is that the case mounting holes for the IR receiver is only compatible with Streacom's own receiver. Now, I ended up just double taping the IR receiver to the side of the chassis, hopefully that'll work. On my case, there are some opacities on the inside of the IR window, but I hope it won't interfer with the signal. I also hope that the glue on the tape is non-conductive
IR receiver taped to side of chassis:
Soon to be covered up. Out of sight, out of mind:
Next up was installing the SSD. My SATA connector was a bit thick, so I had to mount the SSD with only two screws, leaving it installed at a slight angle, to accommodate for the connector.
Harddrive mounting plate installed:
Everything installed and good to go:
I really don't know if it'll work, though. Haven't powered it on yet ! Hopefully, everything will fire up, I really don't want to disassemble the thing again! I'm going to try to install Linux on the box first. Haven't had any real experience with Linux at all, but a first for everything, right?
Nano PSU 150W:
