- Dec 22, 2002
- Conwy North Wales
OK 4PDA5+ arrived and is up and running sooner than I expected, no problems at all with the board booted up fist time, the only hitch was the new 2.4 c MO CPU had a bent pin only VERY slighlty but enough for it not to drop in place, I used a very fine needle just to get it straight, and it worked ok has anyone else ever had bent pins on CPU? do I have anything to worry about ?
Anyway I have set it up using a standard WD hard drive for now as I could not make my mind up which sata's to order the SP94 fits with room to spare with TT smart fan, I am also using ocz 4200, the bios will allow 3 volts vdimm not sure what you get ? not sure how you check? will leave it run a bit before I start to overclock, will keep you posted.
