HEY PEOPLES. I have a problem.. hehe
I got all these chips for my brothers new computer... they are..
Gigabyte -7DXC MOBO
AMD thunderbird 1.1GHZ -CPU
ELSA geforce 2 GTS 32mb - VGA
IBM 45gig 7200 - Harddrive
128 DDR RAM !!
okay there ya go.. i have all that, i am positive that i set it all up right, but like, when i start it up, there is nothing that shows up on the monitor.. like there is no input to the monitor... i have switched monitor's.. so it isnt the monitor, i have checked the VGA, because i put in a voodoo3 3000 pci in there. I realy have no clue what is the problem.. there are no beeps when i start it, and all the fans and everything start up and work perfectly, i dont know if it is the mobo*jumpers on it* the RAM or CPU.. i really dont know, if you need anymore information, just post what you need, and i will fill ya in on what you need. Also some things that i could check, to see what the problem is. thanks a lot!
Gigabyte -7DXC MOBO
128 DDR RAM !!
