xTrEmEoVrClOcKr said:Nice, are you going to keep the chip or fix the IHS issue? 4.7Ghz would be a nice little goal .
g0dM@n said:I would lap it or rip off the IHS of a good clocking chip before RMAing it.
Nice clocks... what are your idle/load temps on stock volts and stock clocks? What are your idle/load and voltage on your main OC? Dunno if it was mentioned...
g0dM@n said:Have you made a decision yet?
Also, what's stock voltage..
xTrEmEoVrClOcKr said:BTW, take some pics of your modding! Sen told me it turned out perfect . Also, if your going to fix it / keep it, I would recommend lapping it (Only if you arn't going to RMA it)
4.9 was a "hump" for me too...how much Vc are you running for 4.9? Mine absolutely needed 1.55Vc to be stable enough to PCMark04 @ 5GHz. 1.525-1.535Vc it would start and not score. What are your load temps?Actually 4.9 seems to the best i can do with it! Anything over 290 fsb and it wont boot
Ross said:4.9 was a "hump" for me too...how much Vc are you running for 4.9? Mine absolutely needed 1.55Vc to be stable enough to PCMark04 @ 5GHz. 1.525-1.535Vc it would start and not score. What are your load temps?
Yeah, that idle Vc stinks. I had to wait to redo my vdroop mod to set the Vc any higher because it overvolted so much at idle...would've been 1.60V easy set at 1.55.
dylskee said:Nice results surf. Can you see a big difference now that your on water? I am really considering a water cooling setup but funds are a little tight until i sell one of my cpu's. I'm also considering lapping my 661 since it's not selling. My IHS isn't that bad but it can only get better after a lap job.
