- Thread Starter
- #21
windows vista ultimate, and yes its legit.What version of windows? Is it legit?
Ive always check the temp and its about 47-55 cel
Hrm, got a spare PSU you can try?
well, ive got a generic one.. thinking it might be the psu?
Couldn't hurt to check. Black screen crashes make me lean in that direction. A generic PSU should be able to handle that system for a little while, you're pulling under 200 watts gaming.
Wouldnt that damage my video card? Since it will lack power?
Nope. The GPU uses very little power. Like I said, your whole system uses less than 200 watts.
I highly doubt 60c is "overheating" for a gpu, run furmark to test the gpu.
Viruses maybe?
Any temperature could mean overheating for a GPU if previously its overheated and fryed the cooling system. Another suggestion would be to physically touch the graphics card and see how hot its running on start-up.
I.E. Start you computer and let it boot fully, leave it on for around 10 minutes and just press your fingers on the card. If its really hot, then your card is fryed and i would suggest buying a new one.
So has this graphics card actually been used before with no problems at all?
Have you run a stability test using the nVidia control panel?
