- Sep 7, 2013
use poloniex...it's way better imho.
That's what I don't like about cryptos, lots of accounts on different sites for one coin lol
but I have some BTC on cryptorush, so I need to trade there till I have enough to withdrawal.
Im lost here...
You dont have a BTC wallet, payments are sent to you local btc account?
Please explain the difference?
That's exactly correct....I only use the local bitcoins account. Although on local bitcoins it's labeled as a ''wallet'', I'm really referring to the literal bitcoin client that you would download onto your PC and has to sync with the network and all that jazz.
That seems pretty high. Have you tried swapping onto your main rig?
Is that a bios flashed 290? I cant beleive it pulls that much. Did you see the efficiency thread? I have a 4930k and 2x 290x that sucks only 725w. 875 watts with primeminer running 12 threads and both gpu's mining.
Didn't Ivan run his 290's undervolted and overclocked a bit? to like 975 Mhz core or something?
Maybe you cards need more power than others??
I have three 290's going and it's at 955w for my rig.
So what's new in this version?
Improved Stability - we've identified stability issues and rewrote the code to mitigate the freezes and hang ups. We've also found and fixed a couple memory leaks that would manifest in certain conditions.
Pool Setup Wizard - this feature allows you to add or switch pools on all, or selected, miners in just a few short steps. The wizard gives you several options for assigning worker names to each miner. There are also options to replace pools and to save pool changes so they persist even after the miner is restarted.
Remove Selected Pool from Miners - remove a pool from all, or selected, miners in just a few clicks. This feature, as well as the Add/Switch Pool Wizard, can be accessed by clicking on Pools in the toolbar, then right-clicking on a pool.
Disable Graphical Enhancements - this option in Settings -> Display will reduce the graphical footprint of CGRemote so it uses less GPU resources when it is running on a computer that is also GPU mining.
Sending Coins to CGWatcher - this feature has been improved, allowing you to manage all of your coins in CGRemote, then have them pushed out to your miners running CGWatcher. Coins you've manually added, as well as adjustments and the 'Do not remove' flag are also now sent to CGWatcher. Not only does it make managing coins easier, it can also dramatically reduce API calls for those users who have purchased API access on CoinWarz.
Network Data Usage - In Settings -> Network you can view the data usage (bytes sent and bytes received) from communicating with the miners. (This does not include web usage, such as downloading coin profitability data.)
Increased Miner Size in Grid View - We've increased the size of each miner in grid view just enough to show more of the coin and pool.
Device Window - When viewing a device, the window is now updated whenever the miner is refreshed. More information has been added, as well as a control panel for GPUs allowing you to change settings, enable/disable, and restart them.
Hide/Un-hide Miners - You can now hide selected miners you don't want to see without having to remove them.
Text Editor Line Returns - We've fixed the Text Editor line returns so the text appears correctly, and the line returns are even preserved during copy/paste with Notepad.
Minimize to System Tray - When CGRemote is minimized, it will disappear from the taskbar and present an icon in the system tray. To restore the CGRemote window, just double-click on its system tray icon.
Many Other Bug Fixes and Improvements - We've fixed settings that didn't work correctly, fixed the issue causing the wrong coins to be displayed for current pools, added support for new miners like SGMiner and VertMiner, and literally hundreds of other changes and improvements.
stupid question -- what the hell is a 'faucet' for a coin?
