- Mar 15, 2001
I was reading through many posts here on the cooling board and i noticed that many people are worried about thier idle temps. I have a question for you. Why? Why would you worry about getting your idle temp lower? What good does that do you? Why would you even want to run your cpu idle? (Ok, I have more than one
First, the reason that I see not to worry about your idle temps is that those don't effect your stability...since you aren't doing anything, what can be unstable? Getting it lower will just, well, lower the activity (assuming constant load temp) of the cpu at idle. Which means it's doing less. Which is fine, except it doesn't really do anything helpful for you. It just increases the amount of temperature fluctuation when you load a program. Temperature fluctuation is bad. I believe that chips like to be at a constant temperature more than they like to be at a low temperature (within reason, of course). So in my view, lowering the idle temp could actually harm the cpu.
Of course, I feel that idle temps are completely irrelevant for more reasons that just those. There is also the fact that an idle temp will probably never be the same, as there are varying loads on the processor when there is an OS running (eg system calls, sentient programs, etc, etc). Then there is the fact that i don't even understand why you would want your cpu idle. Wouldn't you rather have it active? Isn't that why you paid good money for it? So that you can use it? Or did you just want to be able to say that your processor is at ambient temperature when it isn't doing anything PH34R |V|3!
In conclusion, just say No! to idling your cpu.
