- Oct 15, 2001
- Tennessee
batharoy said:
EXCELLENT!
Just for that, I'm going to fold proteins under your username for a while.
batharoy said:
Oh dude you're my hero. I have been trying to find forums/guides like that for like 4 days.sixshot666 said:Doom 3 level editing forum.
doom 3 editor tutorials.
Abrams wants the code to be 901.
read the I.T security email.
I noticed in one of the restrooms(dark) when you point your flashlight at the mirror it doesnt reflect at the wall behind you.
rsjrv99 said:What tweaks have you done delljunk to make that game run that smoothly on the 9800 pro? I can barely run mine at 1024x768 @ high.
no problem.bojangles said:Oh dude you're my hero. I have been trying to find forums/guides like that for like 4 days.
delljunks said:Well yours is o/ced almost to the same core and memory speeds, so that's not the difference.
It runs without any tweaks, but I messed with the cfg file (make a backup first)
set image_useCache "1"
set image_cacheMegs "256"
set image_cacheMinK "20480"
set image_downSizeBumpLimit "512"
set image_downSizeBump "1"
and I opened console with ctrl+alt+~ and typed: set com_videoRam "128"
just to get loading times to go quicker and less pauses when opening doors
oh yeah and your cpu will suffice, but i'm 800 mhz ahead (which does make a difference, I have a friend that has 2.4ghz and I can tell a difference between even 400 mhz)
good luck![]()
Tall_Dallas said:OK. I'm stuck in Doom 3.![]()
I saw the room with the BFG and I can't find the PDA that has the code to get in... now I know I can just grab the code to the door online, but I'd much rather not "cheat" so can someone give me a hand?
I've gotten everything else and the guy is ready to put me through the teleporter. But I WANT THAT BFG!!!
Oni said:You pick up the PDA w/ the BFG code shortly after starting Alpha Sector 4. Let the guy out of the chamber (Don't turn it on! Just open the door) then follow the door to the right, go down the elevator, through the coridor to the guy you let out. Follow him into the room there, listen to his shpiel, and grab the security officer's PDA (it's bright red, can't miss it) and listen to the audio log. The code is in there.
RHARLE10 said:Hey peeps just wondering if you help me out here. I am stuck pretty bad on Monorail i`m trying to find the Delta Labs but i just keep going up and down the lift and there is a door upstairs and a door d/stairs that i can`t get into.
Any help much appreciated
RHARLE10 said:Hey tall dallas i know the bit you`re talking about and i`ve already done that bit where u raise the cart i`m further on now looking for the delta labs and there isn`t a railway line or cart in sight.
The bit i mean i think you had to turn off the pumps or something via the controls up the stairs but its the level just after the one where u raise the cart and after that your objective is to find the delta labs.
