- Feb 26, 2020
- Northeast Ohio
- Thread Starter
- #101
You ahould wait until you reach your established idle temperature. Or when you get your temp sensors, when the water goes back to the starting temp...
I think you need to move past your 'liking' and adhere to what the specifications tell you is safe. 80C for the MOSFETs on that board are fine.
As far as heat soak... welcome to modern big boy(read: many cores and threads) computing! All blocks deal with that...the level varies by board chip and load.
I still think you need to set a static voltage and clockspeed just due to how AMD chips work.
While 80C, 90C, 100C might be within operating parameters, it doesn't mean I shouldn't attempt to mitigate the high temperatures. I'm not sure what the upper limit that will be reached running a long 200W test. Stressing the components when there are a lot of options to offset the issue doesn't make sense to me. I've seen MOSFETs and PCBs melt thermal adhesive and catch on fire on h-bridge motor controllers, and they worked right up to the point where some physical transformation rendered them fatally damaged. This is logic and power components married together, and I can't just let it go and send it at this point. I am going to try a fan first, and I think the airflow across the heatsink and the air movement up and under the heatsink that removes the stale air will get me a solid 5-10C off of that top number. The exhaust fans above will do the rest. At that point I can just send it and perform my tests to my planned specifications.
I'm working on messing with OC options to dial in something specific. Right now the 200W benchmark is something that I can comfortably say is repeatable within the specified timescales. I can work into something even more solid as I continue to deepen my understanding of Ryzen... which is a pretty incredible thing. I'm still a novice in all aspects.
Edit: Have to work some early overtime tomorrow, so it's time to shut this thing down or I'll be up all night again... Thanks for all the input!
