i "use" an e5200 in my HTPC. I say "use" because my HTPC is currently out of commision due to no mobo.
I tested it once in my gaming PC, idle temps were at 45 with intel stock HSF
Cheers bobnova.
Failed after 17 mins though lol
Temps aren't gonna be an issue but im already on 1.39vcore (bios) 1.36 (cpuz), so only 2 notches away from 1.4 which i dont really wanna pass.
I dont really know of any other way to stabilize it. All my games work well and my system seems stable, but 17mins small fft's is clearly not stable.
Any ideas anyone? xD
Can I join? I has E5300.
Did you try any extra vtt? It didn't really help me, but it might help you.
I decided to borrow your your settings 'bobnova'
308x12.5
and bumped pll up a notch to 1.65
1.393vcore (bios) 1.360 (cpuz)
And presto, everything seems stable so far - 39 mins small fft's so far xD
I have no idea what pll is but it seemed to have a nice impact on stability.
What where your temps at this speed?
Ive got 35c idle 58c load
I believe we have the same cooling so would interest me see the diff
Vtt is also known as something else, my motherboard doesn't list it.
1.2FSB Termination.
308x12.5
Quick question about acceptable temps on the e5200. For reference, I'm using an MSI Neo3-F, Rosewill RCX-Z775 heatsink and Tuniq TX-2 compound with an overclock of 300x12.5 @ 1.365v (1.35 after vdroop).
Idle - 38-40c @ 24c ambient
BOINC load - 50c @ 24c ambient
OCCT load - 62c @ 24c ambient, max temp 8 hour burn in.
Linpack load - 71c @ 24c ambient, max temp 8 hour burn in.
I thought these temps might be a little on the high side, so I wanted to get a reference temp @ stock frequency and voltage. Strange thing though is that when I set voltage to "default" on my MSI board it reads 1.37v on CPUz and temps aren't much better. I'm wondering if these temps seem acceptable, it's stable but a little concerning.
