- Aug 5, 2002
digerati said:Well, I said Voltages, but I wes really interested in the Amp readings...
Although, I could do the math...
I'm really curious about this PSU, with its dual 18A 12v rails... I'm concerned it isn't going to hold out with the CPU OC, all the fans and now the GPU pulling 30A...
I really need a single rail 30A+ deal, right?
Its not pulling 30A from anything. Thats a rough reading of 30A being pulled from the GPU or Regulators at a certain voltage.
It only needs 10-11Amps on a 12V line to run really un-OCed. Out of the box its around 120W for the whole card. Add in some voltage and clock increases they of course it will go up but theres no way you'll need 30A on a line. Many run it off of a single 18A line, so surely you can.
Have you tried to un-oc your CPU and unclock the other card to see if thats the issue?
